ApexNM
Aug 23, 2017Aspirant
CM500 Intermittent Connection
I just installed a new CM500 cable modem and the connection has dropped intermittently averaging once an hour and the modem reboots. Here is the error log after the most recent one:
vkdelta
Aug 23, 2017NETGEAR Employee Retired
you have too many Dynamic Range window violations.
Please post your power values.
ApexNM
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- ApexNMAug 23, 2017Aspirant
Note: The upstream channels have been going up and down in power, as well as locking/unlocking. This is like 10 minutes removed from the first data set:
Upstream Bonded Channels (Partial Service) Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Not Locked Unknown 2 0 Ksym/sec 24200000 Hz 0.0 dBmV 2 Not Locked Unknown 1 0 Ksym/sec 19400000 Hz 0.0 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 30600000 Hz 44.5 dBmV 4 Locked ATDMA 4 2560 Ksym/sec 37000000 Hz 43 dBmV - vkdeltaAug 23, 2017NETGEAR Employee Retired
your line from ISP has problems. they would need to fix something at node level to make it work.
