scoobyd
Feb 21, 2021Aspirant
CM500 intermittent drops with T3/4 timeouts and Dynamic Range Window violation
Hi- I've been having problems for about a month with frequent intermittent connection drops lasting anywhere from 10 seconds to 5 minutes. Cox came out last week to check the lines and determined everything was fine, so they swapped my Netgear CM500 modem with one of their "Panoramic wifi" Arris TG1682G modems. That fixed the issue, so they determined my CM500 modem was faulty. Each modem was connected to my my Netgear R6700v2 router.
I had some time today so reconnected the CM500 modem and called Cox to activate it. Within an hour the connection issues started happening again, with frequent "Dynamic Range Window violation," "Unicast Ranging Received Abort Response - Re-initializing" and "Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out" errors occurring along with connection interuptions.
Connection tables and logs are below. Power levels look good from what I can see, but wondering if anyone sees any other issues. This modem is only 2 years old so I'll be disappointed with Netgear if it's already faulty.
Thanks
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Current System Time:Sun Feb 21 21:17:15 2021 |
UPDATE: Amazon agreed to replace the defective Netgear modem even though it was out of warranty. The replacement modem has been working fine, so it wasn't a wiring or ISP issue. I'm glad Amazon stands behind the products they sell when Netgear would not even talk to me about their defective product without charging a fee for customer support. Let's hope this one lasts more than 2 years.
Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853- scoobydAspirant
