ragerDuane
Mar 01, 2021Guide
CM500 Intermittent Drops
I few weeks ago I moved and got a new ISP. With my old ISP I never noticed any internet problems. With my new ISP, at first they left a splitter in my line, which was causing major internet outages. T...
Mar 02, 2021Guru - Experienced User
Your logs indicate the power is going in and out of spec. That's the dynamic range window violations.
And the errors on the connections page indicate issues with the line as well.
If you have any splitters, amplifiers, or attenuators in the coax line, remove them. Move your modem to right where the coax comes into the home and connect there with a direct connection (no other splits/connectors). The ensures its not wiring in the home causing the issue.
ragerDuane
Mar 02, 2021Guide
I've got my modem right where the line comes in the house, no splitters or anything. Would you recommend me getting ISP to come check the outside line again?
- plemansMar 02, 2021Guru - Experienced User
You're caught in a quandary.
Some isp's charge to check the line if there isn't an issue or if its external to the home.
but your line is showing issues.
so its either the modem or the line.
If you had a backup modem you could try and if both had the issue, then you know its the line.
