z_zk_z
Mar 12, 2021Follower
CM500 isn't talking to ASUS RT-AC68R but works with PC
Got a Netgear CM500 installed with Xfinity, it works when connected to my Windows PC and I can access internet (all green LEDs). I get no Internet access when I connect my ASUS RT-AC68R to it (CM500...
antinode
Mar 12, 2021Guru
> [...] I can access internet (all green LEDs). [...]
That would seem to absolve the CM500 of blame.
> [...] What settings should I have on my ASUS Router? [...]
You came to a Netgear forum to ask that question?
> [...] how will it get the WAN IP information? [...]
Presumably, it'd get it the same way that your (happy) "my Windows
PC" got its. My guess: DHCP from your ISP.
> [...] I know the CM500 has no DHCP server. [...]
True, but it seems to provide a good connection to your ISP, and
_they_ have one.
> [...] Any help is greatly appricated...
You might find some relevant information in a widely neglected
resource:
https://en.wikipedia.org/wiki/RTFM
In this case, that'd be the documentation for the router.
It might help if you shut down the CM500 and your router, then
started the CM500, and, when the CM500 looked happy, your router.
