Lefti3
Jun 29, 2020Aspirant
CM500 keeps DC'ing
Hi, I recently got Xfinity internet but the internet signal keeps disconnecting atleast couple of otimes everyday and at random times. The xfinity tech came here because my two cable inputs were n...
Jun 29, 2020Guru - Experienced User
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
Ask the ISP to check the line and there logs when this happens to see if they notice the same time.
I would try another modem as well, sometimes refurbishes items can be problematic.
robturpin
Jul 20, 2020Apprentice
Hi, I purchased my CM500 brand new from Amazon about 6 months ago, and it's doing the exact same thing! This is ridiculous. It will simply drop the connection, and then regardless of whether I call Comcast or not, it starts working again within about 5-10 minutes. It did it both yesterday and tonight, and so I called Camcast and after waiting on hold for over an hour, I was told by the person that my modem shows that it's offline. She further said that their attepmts to re-provision it keep failing, and that the error is coming from my device - NOT their service. I don't care who or what the issue is, but it's wuite strange that SEVERAL people are having the EXACT same issue using this particular modem with COMCAST service. Can someone please help us figure out exactly what is going on here? I can't pay for anyone to come out and "check" or service my cable lines, as I'm currently unemployed and only kept internet to look for work. Thank you!!
- FURRYe38Jul 20, 2020Guru - Experienced User
Be sure to power OFF the modem for 1 minute them back ON.Ask the ISP to check the line and there logs when this happens to see if they notice the same time.
robturpin wrote:Hi, I purchased my CM500 brand new from Amazon about 6 months ago, and it's doing the exact same thing! This is ridiculous. It will simply drop the connection, and then regardless of whether I call Comcast or not, it starts working again within about 5-10 minutes. It did it both yesterday and tonight, and so I called Camcast and after waiting on hold for over an hour, I was told by the person that my modem shows that it's offline. She further said that their attepmts to re-provision it keep failing, and that the error is coming from my device - NOT their service. I don't care who or what the issue is, but it's wuite strange that SEVERAL people are having the EXACT same issue using this particular modem with COMCAST service. Can someone please help us figure out exactly what is going on here? I can't pay for anyone to come out and "check" or service my cable lines, as I'm currently unemployed and only kept internet to look for work. Thank you!!
- robturpinJul 21, 2020Apprentice
Hi,
Yeah, I read your suggestions in the previous posts.
There are no splitters inline from the box to my modem, only one wallplate which uses a single connector. BOTH of the two cable lines are high quality Comcast cables, with factory ends and no splices. I've lived here for 4 years, and did not have this problem with my old modem, so I highly doubt that it's a cable line issue.
I have disconnected ALL cables from the unit and waited for aver one full minute before reconnecting them, but as I said previously, the service restores itself after 5-10 minutes even if I do absolutely nothing. It MUST be either some signal that it's receiving from Comcast, and/or the modem being stupid.
I will contact Comcast to see if they will come out and inspect the lines, etc., but I simply cannot pay them a fee. I'll just drop my internet before doing that.
Thanks for your help
- FURRYe38Jul 21, 2020Guru - Experienced User
Try a different modem as well to see if the problem continues or not.
