Dexrngr
Nov 02, 2019Tutor
cm500 keeps loosing connection
I’ve had this router for 2+years. All of the sudden about 3 weeks ago I keep loosing my internet connection. Unplug for a minute then plug back in and it will work. Sometimes for days other times for ...
- Nov 04, 2019Please screen snip it. It's easier to read
Dexrngr
Nov 04, 2019Tutor
last 2 are the connections snips
capture and capture 1
Nov 04, 2019Guru - Experienced User
Way to many errors on your downstream and your upstream power is to hot.
Your ISP needs to check your lines. If you have splitters, amps, bad coax, 90 degree elbows, bad/loose connectors replace them. They can cause errors too.
- DexrngrNov 04, 2019Tutor
ok thank you. im pretty sure i on a straight line from my outside connection. which comes down to my wall jack and to my modem.
what should my normal upstream and downstream look like?
- plemansNov 04, 2019Guru - Experienced UserThis article goes through some basics.
https://pickmymodem.com/signal-levels-docsis-3-03-1-cable-modem/
