DodgerJeff
Jul 28, 2017Aspirant
CM500 Login problems
I have used the paper clip to factory reset my CM500 and when I go to 192.168.100.1 and try using the default ADMIN and PASSWORD to login it tells me that I am wrong. Also when I go to this address ...
DarrenM
Aug 03, 2017Sr. NETGEAR Moderator
Hello Dodgerjeff
No that is not right do you have a Ubee router? also what are you trying to access in the CM500 should not be any settings you would need to change in the cm500 only has the logs.
DarrenM
DodgerJeff
Dec 09, 2017Aspirant
Also I am using Netgear Genie and when trying to login using "admin" and "password" doesn't work to do any changes to the settings. I have reset the modem and these default login passwords are letting me in.
