Starrman03
Jul 20, 2018Aspirant
CM500 losing internet connection and upload/download amber
Hi there,
My CM500 intermitantly loses internet connection quite often (Sometimes 5+ a day, sometimes for up to 4+ hours before it decides to work again) . The upload and download will go ambe...
DarrenM
Jul 25, 2018Sr. NETGEAR Moderator
I see alot of T3 timeouts this suggests it could be a line issue with the ISP I would have them send out a tech and check the lines inside and outside the home.
DarrenM
- Starrman03Jul 25, 2018AspirantUnfortunately I have. When they came out they tested the line and said everything was good. The problem is intermittent, so I'm wondering if that's why they didn't find anything.
- vkdeltaJul 25, 2018NETGEAR Employee Retired
also, your Upstream power very high. If you additional splitter, please remove check the connections.
You need upstream powers to be around mid-40s and yours is above 50.
It is plugged directly into an outlet.
