jsnim
Aug 15, 2022Aspirant
CM500 Modem all lights solid amber; internet green
For whatever reason, the modem has all lights a solid amber and the internet light is green, but we don’t have internet. Unplugging the power to restart, hitting the reset button or anything else does...
Aug 15, 2022Guru - Experienced User
Try a different power adapter with same volts and amps and see. Possible the modem could be bad.
Are you able to access the modems web page at 192.168.100.1 with a wired PC and web broswer?
