Khendu
Apr 26, 2021Aspirant
CM500 Modem Connection Drops & Error Logs
Over the past several weeks, I've experienced an increasing frequency of internet connection drops. While some are short (10-30 secs.) and will reconnect without powering the modem and router down a...
Apr 26, 2021Guru - Experienced User
Please use the Choose File button option and attach your capture files. Otherwise we have to wait for a forum moderator to approve your pictures.
Khendu
As suggested, I deleted the pictures and attached a PDF with the screen captures via the Choose File button.
- FURRYe38Apr 26, 2021Guru - Experienced User
Got lots of T3 Criticals in the logs. Something the ISP should look at as well.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://highspeed.tips/docsis-events/
