chellesmeow
Mar 01, 2017Aspirant
cm500 modem connects to ethernet on computer but cannot connect through router
Hi, I just bought a CM500 modem to replace an outdated surfboard. I can connect if I use the ethernet port on my computer but when i try to connect to my router (and then connect the router to the et...
chellesmeow
Mar 03, 2017Aspirant
No, I don't know how to do that? I unplugged it and plugged it back in as the modems manual told me to.
DarrenM
Mar 03, 2017Sr. NETGEAR Moderator
Hello chellesmeow
You may want to look up how to factory reset your linksys device.
DarrenM
