tonisama
Jun 04, 2020Tutor
CM500 Modem gets half speed when connected to router but full speed when connected to PC
I recently purchased a used CM500 to replace a Mediacom-provided unit that we rented. We subscribe to 100/10 internet service and have always gotten full speeds. The CM500 was provisioned and I ...
- Jun 04, 2020
I'd try a different modem. Maybe a CM600/700 or CM1000 if these are supported by your ISP.
Jun 04, 2020Guru - Experienced User
Did you power OFF both CM modem and router for 1 minute then back ON with the modem first then router?
What is the mfr and model# of the router your using?
- tonisamaJun 04, 2020Tutor
I just tried and it had no effect.
The one that I use currently is a TP-Link Archer A6 AC1200. I also have an old Netgear WNDR3700v2 N600 which I just tried and it also has the same issue.
