ragerDuane
Jan 23, 2021Guide
CM500 Modem keeps dropping internet, then reconnecting eventually
I used to use my CM500 modem with R6700v3 router with Vyve Broadband at my old address. I never had any significant internet issues. I moved to a new location and got service with Sparklight. Everyth...
- Jan 25, 2021
Check you line for amplifiers, attenuators, or splitters. remove them if you have them. check the line for damage, kinks, cheap/old/bad/loose connectors.
Reason is your power levels are out of spec. They're to low and they should only be 3.5dbmv from each other. You're going from -11.2 dbmv (with errors) to -0.1dbmv. so 11.1dbmv difference. couple that with the logs and theres issues with the line.
if you checking your side of things doesnt help, then the isp needs to check that.
ragerDuane
Jan 24, 2021Guide
I couldn't get a legible copy and paste, so a pdf of the connections is attached above.
Jan 25, 2021Guru - Experienced User
- ragerDuaneJan 25, 2021Guide
Thank you for that information! I will do that and then follow up on here.
Thank you! That solved it. The ISP came and found a splitter on the outside of the house. They also suspect that an old cable could be damaged because it was run on top of the roof, fully exposed to all the elements for who knows how long. Cable connection looks great now, I have attached it to this post for reference.
- plemansJan 25, 2021Guru - Experienced User
Much better looking connections page. Everything is within spec.
Glad it took care of the issue!
Let us know if you have other problems.
