oldmunkayman
Apr 03, 2022Aspirant
CM500 Modem keeps dropping internet
In the past few days, my internet keeps dropping, and I have to turn off/on my modem multiple times throughout the day. Sometimes it will fix itself within a few minutes. Some recent changes are that...
Apr 03, 2022Guru - Experienced User
Your logs are indicating line issues.
Do you have a screen snip of the cable connections page?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- oldmunkaymanApr 03, 2022Aspirant
Thanks, that is helpful. Here is a photo of the cable connection report.
- plemansApr 04, 2022Guru - Experienced User
Between the errors you have and the logs, you have a line issue.
Check the line like I'd advised before and try it. If that doesn't help, then the ISP needs to check the line.
