oldmunkayman
Apr 03, 2022Aspirant
CM500 Modem keeps dropping internet
In the past few days, my internet keeps dropping, and I have to turn off/on my modem multiple times throughout the day. Sometimes it will fix itself within a few minutes. Some recent changes are that...
oldmunkayman
Thanks, that is helpful. Here is a photo of the cable connection report.
Apr 04, 2022Guru - Experienced User
Between the errors you have and the logs, you have a line issue.
Check the line like I'd advised before and try it. If that doesn't help, then the ISP needs to check the line.
