jc107
Nov 23, 2022Aspirant
CM500 Modem Keeps Restarting
I have had this modem for a year and half and had no issues. For about a week now, the modem keeps restarting - all the lights on the modem turn off. Sometimes this is for 1 minutes, other times its ...
Nov 23, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
I see a critical that the ISP should review and resolve.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
jc107
My router is Google Wifi model: AC-1304
There are no splitters between the modem and the cable box that I am aware of.
What do I need to tell my ISP to look into exactly?
- FURRYe38Nov 23, 2022Guru - Experienced User
Any Errors or Critical seen in the Events Log page needs to be reviewed by the ISP and resolved by them.
You have a couple of channels that are running near High power levels and some that are running at negative power levels. There all over the place. All channel needs to be around the same power level across the board and not all over the place.
The ISP needs to check this out. A tech visit maybe needed.
- jc107Nov 23, 2022Aspirant
When I called my ISP originally, they said it was my modems problem since it kept completely powering off and they couldnt do anything about it since it isnt their modem and I need to contact Neatgear. What should I tell them they need to do exactly? Sorry, I dont know much about networking.
The link you posted said they should all be between -7 and +7, which they are. But should they be closer? How do I fix that?
Thank you!
