Routemetothenet
Apr 28, 2020Follower
CM500 Modem to NETGEAR WNR2000v5 No Wireless Connectivity
Hello so I have a 2nd Hand CM500 Netgear modem, that is connect through xffinity it works hard wired to my laptop, But it will not connect to my NETGEAR WNR2000v5 router that i own for years and i k...
Apr 29, 2020Guru - Experienced User
THe WNR router is EOL and would probably be a bottle neck with your modem. I recommend getting into a newer generation router.
Please post about your router model here:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
