AshlandLady
Aug 27, 2022Initiate
CM500 Modem with blinking red ethernet light
Our CM500 Modem is connected to the internet and we have a MeshForce M1 router connected to the modem. We are receiving wifi, but for some reason, the ethernet LED light on the modem is blinking red,...
AshlandLady
Aug 28, 2022Initiate
Thank you. I don’t understand all that, but I’ll take your word for it 🙂
Aug 29, 2022Guru - Experienced User
Basically it means the modem is capable of 10/100/1000mbps connections. But the router isn't. It only has 10/100mbps connections.
So when you connect it to the modem, the modems amber light is signifying its only connected at 10/100mbps speeds.
If it was the faster 1000mbps connection, it would be green.
green=1000mbps connection
amber=10/100mbps connection
