Lodi's avatar
Lodi
CM500 Network Light Off
Good morning! The Network light on my CM500 is off.  All other status lights are green. I cannot connect to the modem from the network or via direct connection.  We had a storm last night so I'm wondering if the modem took a surge of some sort.  All other equipment seems fine.  I tried resetting and no luck.  I suspect I will be buying a new modem this morning but thought I would check here first.  Thanks in advance for any thoughts.
  • Lodi's avatar
    Lodi
    Dec 30, 2021
    Thank you. Tried it but no go. I replaced it w/a CM1200. Everything is back in order.
  • plemans's avatar
    Storms are great at wrecking electronics.
    Something to try though.
    Disconnect the coax from the modem.
    Then push and hold reset for 7-15 seconds until the lights blink.
    When its fully rebooted after the reset, power it off for a couple minutes.
    Then connect the coax back to the modem.
    Then power it on and wait a couple minutes.
    Then connect a pc/laptop or your router to it with a new ethernet cord.
    • Lodi's avatar
      Lodi
