Kel22
Apr 06, 2020Aspirant
Cm500. Network name does not appear on devices
My WiFi does not appear on any of my devices. The WiFi coming into the house works but the name does not appear as a choice. We did reset it from the back. CM 500
Apr 06, 2020Guru - Experienced User
CM500 is a modem only. It doesn't have a router or wifi built in. Its strictly modem only.
Kel22
Apr 07, 2020Aspirant
Thank you for replying. We finally did figure out that our problem was the switch. Modem wasn't talking to the Router.
- plemansApr 07, 2020Guru - Experienced User
hopefully you don't have a switch between the router and the modem.
it should go modem------>router------>switch
- Kel22Apr 07, 2020Aspirant
We've taken the switch out of play. For a long time it was the T-Mobile Cell spot going into the NetGear switch along with the Orbi router going into the switch and the switch connected to the modem. Now the modem and router are directly connected. The modem only has one port so that was the reason for the switch. I really don't know if we even need that T-Mobile Cell spot. Everything seems to be working fine without it. Our internet is with Comcast/Xfinity.
