U230148
Aug 16, 2021Aspirant
CM500 no connection
I bought a CM500-100NAS from a neighbor to have as a spare, and it only locks into one downstream channel at very low power, -26 dBmV, and no lock on any upstream channel. I have two other modem...
Aug 16, 2021Guru - Experienced User
try changing coax cables. Also, check any splitters,amplifiers, or signal attenuators. remove them if you have th em.
Your correct in that either something is dropping the power or its bad.
The connection info from the known good ones might help. Plus it might tell us why its dropping daily.
U230148
I ran a homerun RG6 from the outside interface to my modem last year when we kept getting the daily drops. It did not help. There is nothing between the interface and the modem except new RG6.
I saw an Xfinity truck in the neighborhood earlier this year, and I chased him down to ask him about the service issues. He was well aware of problems in the neighborhood and was there to troubleshoot. Things are better since then but we still have several short drops everyday. Calling support is of little use because they require you to reboot the modem before they will help, and typically by then the drop has ended.
- plemansAug 16, 2021Guru - Experienced User
Try it back at the neighbors house you got it from. See if the signal is bad there as well.
- U230148Aug 16, 2021AspirantAfter 1.5 hours the Motorola modem has accumulated 61 corrected errors, no uncorrected errors. Error log is still clear.
In the past I've connected the modems directly to the outside Xfinity interface, and we still had the short drops in service. That's convinced me that the problems are Xfinity's and not mine.
I'll try connecting the CM500 to the Xfinity interface, and if there's no improvement I'll conclude it's defective. Is there any other reason to have good signal levels on two modems and nearly no signal on a third?- plemansAug 16, 2021Guru - Experienced User
no.
if there's 2 good ones. its probably a hardware failure.
I'd be betting on the coax connection in the modem
- U230148Aug 16, 2021AspirantThanks for the replies, I appreciate you taking the time to help out.
I don't think the previous owner has an active cable connection anymore to try it over there.
I may open up the modem and see if there's anything obviously wrong with the cable connector.
