jcgill
Aug 20, 2020Follower
CM500 only one upstream channel and frequent disconnects
My internet connection has been having frequent outages for a while now. I noticed the upstream light on my modem was solid amber and after looking at how to fix that I saw recommendations to look at...
westerj
Dec 17, 2020Aspirant
WHat can I learn from Critical and Warning entries in my Event Log? I'd like to separate findings that are my responsibility from those of my ISP. EX:
Critical (3) No Ranging Response received - T3 time-out;
Critical (3) Unicast Ranging Received Abort Response - Re-initializing
Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Critical (3) Started Unicast Maintenance Ranging - No Response received -
Unicast DSID PSN startup error
No UCDs Received - Timeout
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;
SYNC Timing Synchronization failure - Failed to acquire FEC framing
DHCP WARNING - Non-critical field invalid in response
Honoring MDD; IP provisioning mode = IPv4
Are there docs for these logs?
Thanks!
Dec 17, 2020Guru - Experienced User
westerj Please start your own thread. Include screen snips of the logs and cable connections page. Easier to read.
some basic info
https://pickmymodem.com/signal-levels-docsis-3-03-1-cable-modem/
