Shadowtsi
Dec 09, 2017Aspirant
Cm500 rythmic blinking of Ethernet light
Hello, Thanks for reading. So my ISP had an outage 2 days ago. After when it came back my Ethernet light started a rythmic blinking (not random blinking showing traffic). Also no internet to rou...
DarrenM
Dec 12, 2017Sr. NETGEAR Moderator
Have you tried a new cable or reset your router?
DarrenM
- ShadowtsiDec 12, 2017AspirantYes
- DarrenMDec 13, 2017Sr. NETGEAR Moderator
You may want to contact support if you think something happened to the modem.
http://www.netgear.com/support/contact.aspx
DarrenM
