DukerOfHazzard
Feb 16, 2021Aspirant
CM500 signal keeps dropping
Hello everyone, Like many other people before me, I am having issues with my CM500 cable modem. It will drop signal randomly for periods of the day; sometimes correcting itself quickly, other tim...
- Feb 16, 2021
You're getting a lot of timeouts. Thats when the modem isn't connecting back to the cmts. Tends to be line issues.
You can check your side of the line again for kinks, damage, loose/old/bad/corroded connectors. If you can't find anything, the isp needs to check the line
Feb 16, 2021Guru - Experienced User
here's how to get the logs.
How do I view or clear the event logs on my cable modem or modem router? | Answer | NETGEAR Support
also, get the screen snip of the cable connections when its having issues.
DukerOfHazzard
| Time | Priority | Description |
| 1970-1-1, 00:01:47 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 1970-1-1, 00:00:28 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:22 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2021-2-16, 19:38:00 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 19:10:25 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 19:10:24 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 19:10:24 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 19:10:05 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 19:10:05 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 19:10:05 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 19:08:56 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 1970-1-1, 00:00:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2021-2-16, 18:41:37 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 18:41:37 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-16, 18:40:30 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-14, 11:59:17 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-14, 00:32:07 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-14, 00:32:06 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-14, 00:32:06 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 05:40:42 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 03:23:26 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; |
| 2021-2-12, 03:22:55 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 03:18:54 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 03:18:53 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 03:18:53 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 03:18:14 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 03:18:11 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 03:18:11 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-12, 03:17:03 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-9, 14:31:20 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; |
| 2021-2-9, 14:30:49 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-9, 12:58:19 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-9, 12:58:18 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-9, 12:58:18 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-9, 12:57:10 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-9, 12:00:32 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; |
| 2021-2-9, 12:00:24 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-9, 11:59:33 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
| 2021-2-9, 11:58:34 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.0;CM-VER=3.0; |
| 2021-2-9, 11:58:06 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:4c:21:30;CMTS-MAC=00:01:5c:96:48:53;CM-QOS=1.1;CM-VER=3.0; |
