paperboy201
Sep 24, 2016Tutor
CM500 Slow Download Speeds and Download light blinking green
Firmware Version V1.01.05 For the last few days, download speeds have been painfully slow and only the download light is steadily blinking green. All other lights are solid as they should be. ...
DarrenM
Dec 07, 2016Sr. NETGEAR Moderator
Hello rightintel
I would contact your ISP have them check the levels and connection of the modem also if you have any cable splitters on your cable line try to remove them and connect directly to the wall.
DarrenM
rightintel
Jan 08, 2017Aspirant
No splitters, connections are tight.
Here's the modem log:
1970-1-1, 00:00:20 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:30 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:36 Notice (6) Honoring MDD; IP provisioning mode = IPv4
1970-1-1, 00:00:38 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.0;CM-VER=3.0;
2016-12-27, 16:52:03 Notice (6) TLV-11 - unrecognized OID;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-27, 16:52:46 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 11:19:00 Warning (5) Dynamic Range Window violation
2016-12-29, 11:20:16 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 11:24:44 Warning (5) Dynamic Range Window violation
2016-12-29, 11:25:30 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 11:25:44 Warning (5) Dynamic Range Window violation
2016-12-29, 11:26:00 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 11:27:58 Warning (5) Dynamic Range Window violation
2016-12-29, 12:03:08 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 12:04:06 Warning (5) Dynamic Range Window violation
2016-12-29, 12:04:22 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 12:05:21 Warning (5) Dynamic Range Window violation
2016-12-29, 12:06:37 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-29, 12:06:51 Warning (5) Dynamic Range Window violation
2016-12-30, 11:31:12 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-30, 11:59:35 Warning (5) Dynamic Range Window violation
2016-12-31, 04:52:00 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2016-12-31, 17:24:58 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-3, 16:52:00 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 11:40:05 Warning (5) Dynamic Range Window violation
2017-1-8, 11:41:21 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 11:59:16 Warning (5) Dynamic Range Window violation
2017-1-8, 14:31:11 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:31:14 Warning (5) MDD message timeout;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:31:15 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:31:18 Warning (5) MDD message timeout;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:35 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:38 Warning (5) MDD message timeout;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
2017-1-8, 14:32:44 Warning (5) MDD message timeout;CM-MAC=40:5d:82:f0:55:b8;CMTS-MAC=00:14:f1:e5:d0:cc;CM-QOS=1.1;CM-VER=3.0;
Help Center
