Gilyem
Mar 03, 2022Guide
CM500 slow internet and my phone wouldn't connect
I have been having issues with my connection lately. I have rebooted both my modem and router. I have connection on my desktop, but not on my S9 phone (says connected without internet). Below is the ...
- Mar 05, 2022
I managed to fix the problem, everything is working as it is again. I was able to contact ISP and they rebooted signals and I relocated my modem and router. All devices are back to normal. Thank you for helping out.
Mar 05, 2022Guru - Experienced User
again, you've got a bunch of errors in your line.
If the issue isn't coming from inside the home, it could be from your isp's setup.
If you've tried everything in your home, then you'd need to contact the isp to check it.
Gilyem
Mar 05, 2022Guide
