Mikerod72
Dec 13, 2019Aspirant
CM500 upstream and downstream lights are solid amber
Both upstream and downstream lights are solid amber
- Mikerod72Aspirant
If you read the manual, it shows solid amber means that one channel has been locked.
That's what your screen snip shows as well.
Are you having issues?
If so, more details help.
- Mikerod72AspirantI did in fact read that, both lights had been green and then one day they turned amber. I didn't know if only one channel being locked was a concern which is why I posted the question in the forum. Was just trying to get ahead of any potential issues.
