CORRY200
Jul 20, 2018Aspirant
CM500 with Orbi speed issues
I have a CM500 Netgear modem with the Orbi RBK50. I do a speed test on Negears Orbi app and I get 454.27Mbps and Upload 23.59. I have Spectrum internet. If I go to Google Fiber site I get 174 downloa...
vkdelta
Jul 20, 2018NETGEAR Employee Retired
what is your subscribed speed?
are you testing with your PC hard wired?
CORRY200
It's 400mbps A wired connection I get 445mbps. I'm justin using my phone to do a speed test. What is the difference from say online test to the Orbi app test that would be that much different?
- vkdeltaJul 20, 2018NETGEAR Employee Retired
This means that CM500 is good, your Orbi wired connection is good as well.
have you checked you actual client CPE device (you phone, laptop, etc). Is it capable of 11ac 5GHz? this looks like wireless CPE problem rather than CM500 issue.
- CORRY20Jul 20, 2018Aspirant
Yes all my devices can do that. I did a speed test upstairs and I get 202mbps on speedtest. Still on the Orbi app I get 456mbps. My modem and router are downstairs. I noticed in the it says the Sattilite has a poor backhaul.
make sure your satellite is closer so that backhaul connection is good.
and test using cell phone on main router to see the speeds first.
