ggahan
May 20, 2021Aspirant
CM500V and Comcast Cable
Comcast only rates the CM500V at 373 Mbps, why? The Voice version is using a base firmware of V1.01.10 and the CM500 has a newer one V1.01.14. If I am not using the voice anymore, could the newer fir...
May 20, 2021Guru - Experienced User
Something to ask the ISP about as they are responsible for any FW updates sent to Cable modems.
ggahan
Thanks for the suggestion. I went there first to see what they had to work with. I was referred to thie list which shows a limit of 373 Mbps for the cm500v and when I checked the cm500, it was the same. Why would there be such a dramatic difference in their implementation of the drivers for the modem and Netgear's advertised speeds with Netgear being an approved modem for Xfinity/Comcast?
- plemansMay 21, 2021Guru - Experienced User
The isp sets the service levels based on their own system and not what the modem is capable of.
Cox is notorious as they've increased to requiring docsis 3.1 for their 400mbps+ tiers. Even though docsis 3.0 modems are capable of hitting gig speeds.
So its on the isp.
