Devons
May 31, 2021Aspirant
CM500v and Optimum
Can someone PLEASE once and for all tell me if Netgear CM500v works on ALL Optimum services? Like others that have posted the CM500v works on internet/cable/WiFi but I get no dial tone for voice. On...
Jun 06, 2021Guru - Experienced User
Youll need to check WITH the ISP. The ISP wil have this information. Not all ISP may support his model modem.
From the spec sheet, it was certified to use on Xfinity. No others were mentioned:
https://www.netgear.com/images/datasheet/cable/CM500V_DS.pdf
Again, the ISP will have this information. Please contact them.
