tillerman71
Jan 04, 2020Tutor
cm500v and r6400
installed cm500v have 200+ mbps at cable modem going through r6400 router only get 0.26 mbps at tv 40 feet away on speedtest help
tillerman71
Jan 04, 2020Tutor
Thanks will do as you instructed will let you know later
tillerman71
Jan 04, 2020Tutor
Thank you so much I did as you instructed and now everything is working, the WiFi signal is strong throughout the house, guess the R6400V2 kept the settings from when it was used with the Xfinity gateway/router.
- plemansJan 04, 2020Guru - Experienced User
Glad to hear you got it working! Sorry it took a little hesitation at the start.
