pcb's avatar
pcb
CM500V and Synology RT2600ac: no internet
Comcast/xfinity is my ISP. In August I replaced the comcast combo modem/router with a Netgear CM500V modem and a Synology RT2600ac router, with another Synology MR2200ac router downstream to extend the range. This has worked great for the last 3ish months, then this week the internet connection started to get intermittant, then dropped completely.
When I connect a pc directly to the modem, the internet connection is great, with DL speeds around 300Mbps. But when I connect the router downstream, there is no internet connection. I tried both routers, and reset everything to factory defaults, with the same results: internet connection on the modem but it doesn't extend to the router. The router page indicates status of GOOD for both phone and router.
Is this a modem setting, or something on the router? Thanks for any advice. Event log pasted below:
TimePriorityDescription
Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv6
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=cc:40:d0:ea:e7:00;CMTS-MAC=00:01:5c:76:42:6d;CM-QOS=1.0;CM-VER=3.0;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:ea:e7:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:ea:e7:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
Fri Dec 06 11:18:14 2019Notice (6)Honoring MDD; IP provisioning mode = IPv6
Fri Dec 06 11:18:05 2019Critical (3)No Ranging Response received - T3 time-out;CM-MAC=cc:40:d0:ea:e7:00;CMTS-MAC=00:01:5c:76:42:6d;CM-QOS=1.0;CM-VER=3.0;
  • plemans's avatar
    do you have a screen snip of your modem connections page as well?
    So it works fine if you have a pc connected to the modem but if you connect the router tot he modem, it doesn't work?
    Usually we tell people if a direct connection works great, then you move on to the next device in line that could be causing issues.
    Have you tried replacing cables?
    Are you booting up in the proper sequence?
    shut both devices off, boot up modem and give it a couple minutes, then booting up the router?
    In terms of checking your router, you'd probably want to ask on the Synology forum as that'd be their device.
    • pcb's avatar
      pcb
      Agreed that it would make sense that it is the router that is causing the issue, but I've tried two routers, both of which worked fine previously. I understand that Xfinity controls the settings on the modem, but I don't have a history of those settings to see if anything has changed.
      I have posted this question on the Synology and Xfinity forums as well, no answers yet.
      I have changed cables to make sure it isn't the cables. I have rebooted with the sequence you describe several times. Unless I figure this out, I'll probably go get a modem from  Comcast this morning to see if/how that changes anything.
      Settings are shown below, starting frequency is 0.
      Startup Procedure
      Procedure
      Status
      Comment
      Acquire Downstream Channel
      621000000 Hz
      Locked
      Connectivity State
      OK
      Operational
      Boot State
      OK
      Operational
      Security
      Enabled
      BPI+
      IP Provisioning Mode
      Honor MDD
      honorMdd(4)
      Downstream Bonded Channels
      Channel
      Lock Status
      Modulation
      Channel ID
      Frequency
      Power
      SNR
      Correctables
      Uncorrectables
      1
      Locked
      QAM256
      29
      621000000 Hz
      2.2 dBmV
      39.2 dB
      0
      0
      2
      Locked
      QAM256
      8
      489000000 Hz
      1.1 dBmV
      39.5 dB
      0
      0
      3
      Locked
      QAM256
      10
      507000000 Hz
      1 dBmV
      37.7 dB
      0
      0
      4
      Locked
      QAM256
      11
      513000000 Hz
      0.6 dBmV
      39 dB
      0
      0
      5
      Locked
      QAM256
      12
      519000000 Hz
      1.3 dBmV
      39.4 dB
      0
      0
      6
      Locked
      QAM256
      13
      525000000 Hz
      0.9 dBmV
      39.2 dB
      0
      0
      7
      Locked
      QAM256
      14
      531000000 Hz
      0.9 dBmV
      39 dB
      0
      0
      8
      Locked
      QAM256
      15
      537000000 Hz
      0.7 dBmV
      38.9 dB
      0
      0
      9
      Locked
      QAM256
      16
      543000000 Hz
      1 dBmV
      39 dB
      0
      0
      10
      Locked
      QAM256
      17
      549000000 Hz
      1.4 dBmV
      39.2 dB
      0
      0
      11
      Locked
      QAM256
      18
      555000000 Hz
      1.6 dBmV
      39.2 dB
      0
      0
      12
      Locked
      QAM256
      19
      561000000 Hz
      2.1 dBmV
      39.5 dB
      0
      0
      13
      Locked
      QAM256
      20
      567000000 Hz
      2.1 dBmV
      39.3 dB
      0
      0
      14
      Locked
      QAM256
      22
      579000000 Hz
      2.7 dBmV
      39.8 dB
      0
      0
      15
      Locked
      QAM256
      26
      603000000 Hz
      2.5 dBmV
      39.6 dB
      0
      0
      16
      Locked
      QAM256
      27
      609000000 Hz
      3.1 dBmV
      39.6 dB
      0
      0
      Upstream Bonded Channels
      Channel
      Lock Status
      US Channel Type
      Channel ID
      Symbol Rate
      Frequency
      Power
      1
      Locked
      ATDMA
      1
      5120 Ksym/sec
      17300000 Hz
      40.8 dBmV
      2
      Locked
      ATDMA
      2
      5120 Ksym/sec
      23700000 Hz
      40.5 dBmV
      3
      Locked
      ATDMA
      3
      5120 Ksym/sec
      30300000 Hz
      40.5 dBmV
      4
      Locked
      ATDMA
      4
      5120 Ksym/sec
      36700000 Hz
      41 dBmV
      • plemans's avatar
        t3 timeouts are fairly common. Not a big deal unless its happening quite requently.
        A couple things you can try.
        1. remove any splitters, amplifiers, attenuators from your line.
        2. prefereably just connect the modem directly where the coax lines enters the house. this prevents the wiring within your house from causing the issues.
        3. Check your connections to make sure they're not loose/corroded.
        4. Check the cables for kinks. Replace them if there are.
        These are some basic things you can do with your modem. Your signal looks great but its only a snap shot in time of when you opened the connections page. It also works when you plug your pc/laptop in. It makes me think its not the modem. But when it happens with more than 1 router.....anything is possible.
        Any chance you have a non-synology router you could try?
