pcb
Dec 06, 2019Aspirant
CM500V and Synology RT2600ac: no internet
Comcast/xfinity is my ISP. In August I replaced the comcast combo modem/router with a Netgear CM500V modem and a Synology RT2600ac router, with another Synology MR2200ac router downstream to extend t...
pcb
Dec 07, 2019Aspirant
Note that I contacted Synology tech support as well, and they agreed with the conclusion: there is some issue with the Netgear router. I've just slightly exceeded the 90 day warranty; will Netgear stand by this prodcut and issue a replacement? netgear
Dec 07, 2019Guru - Experienced User
If it's a new device the warranty should be a year. But you'd need too go through support. This is the community forum.
Click mynetgear at the top. Register an account and then your device. From there you can contact support
