RAnPC
Jun 05, 2020Aspirant
CM500V Cable Modem Intermittently Loses Connection on Xfinity Network
Within the last few days of late May and early June 2020, my internet connection has randomly dropped and not recovered until the modem was power cycled. Upon each instance of the connection failure...
Jun 05, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
RAnPC
Hello Furrye38,
Thanks for your response.
--This has been performed already with Xfinity. Although some changes were made to the bandwidth and signaling, the problem continues to happen.
--A splitter is needed, as there are not extra drops available that can connect just the modem.
--Currently waiting for next failure to determine if power levels are out of spec for either up or downstream connections.
--RG6 cables were provided by Xfinity.
