Treviart
Oct 12, 2019Tutor
CM500V Connection issues
I have Xfinity, with a reasonble internet connection, and no major issues, but one. I will be surfing on my phone, laptop, etc., and then it will stop for a moment. It will take a moment or two befor...
Oct 12, 2019Guru - Experienced User
so you put that you have the cm500v which is a modem/voice device. Not a router.
What router are you using?
What makes you think its the modem thats causing issues?
Treviart
Oct 12, 2019Tutor
I have a linksys. Not at home, so can’t grab the model #. Do some not play well together?
- plemansOct 13, 2019Guru - Experienced User
I didn't say that. But usually modems are a set and forget. Unless they're having signal problems, they just work. Usually if its something thats fixed but shutting off your wifi and turning it back on (on your device) it tends to be a router issue thats causing it. Not always which is why I ask "what makes you think its your modem?"
Has there been issues with it before?
If you hardwire into your modem and run a device for a while, do you get the drops?
If you take a screen snip of your modem connections page, what does it show?
- TreviartOct 13, 2019TutorThe issue started when I changed modems from the Xfinity-issued modem to the current modem. The connection will temporarily drop. As for the modem connections page, what would I look for?
take a screen snip of the full page. This helps us to determine if your signal strengths are where they should be. Some modems have a little more leeway than others and you could have been borderline on your strength and the switch was enough to cause issues.
here's a super basic write up of what to look at.
https://www.speedguide.net/faq/what-cable-modem-signal-levels-are-considered-good-78
What was your old modem?
have you tried removing any splitters/amplifiers/90 degree elbows from your line?
have you checked your cables? Cheap cables, poor connections, damaged (kinked) wires, moisture in the line can all cause intermittent issues.
