Treviart
Oct 12, 2019Tutor
CM500V Connection issues
I have Xfinity, with a reasonble internet connection, and no major issues, but one. I will be surfing on my phone, laptop, etc., and then it will stop for a moment. It will take a moment or two befor...
Oct 13, 2019Guru - Experienced User
Have the ISP check the signal and line quality up to the modem.
Be sure your using good quality RG6 coax cable up to the modem.
Treviart wrote:I have Xfinity, with a reasonble internet connection, and no major issues, but one. I will be surfing on my phone, laptop, etc., and then it will stop for a moment. It will take a moment or two before it's up and running again. I have to either wait for it to pick up again, or I can turn off my wifi from my laptop/phone and turn it back on, which allows me to go back to what I was doing. Any reasons as to why that would occur?
- TreviartOct 13, 2019Tutor
Here are the stats from the modem just a little while ago.
Modem pic 2
- plemansOct 13, 2019Guru - Experienced User
Your modem is technically within spec but it could be a bit better on downstream power levels. You don't have any uncorrectables though. I'd try directly wiring into the modem with a pc and seeing if it drops. If it doesn't, I'd be looking at the router.
