Treviart
Oct 12, 2019Tutor
CM500V Connection issues
I have Xfinity, with a reasonble internet connection, and no major issues, but one. I will be surfing on my phone, laptop, etc., and then it will stop for a moment. It will take a moment or two befor...
Oct 13, 2019Guru - Experienced User
Have the ISP check the signal and line quality up to the modem.
Be sure your using good quality RG6 coax cable up to the modem.
Treviart wrote:I have Xfinity, with a reasonble internet connection, and no major issues, but one. I will be surfing on my phone, laptop, etc., and then it will stop for a moment. It will take a moment or two before it's up and running again. I have to either wait for it to pick up again, or I can turn off my wifi from my laptop/phone and turn it back on, which allows me to go back to what I was doing. Any reasons as to why that would occur?
Treviart
Oct 13, 2019Tutor
Here are the stats from the modem just a little while ago.
- TreviartOct 13, 2019Tutor
Modem pic 2
- plemansOct 13, 2019Guru - Experienced User
Your modem is technically within spec but it could be a bit better on downstream power levels. You don't have any uncorrectables though. I'd try directly wiring into the modem with a pc and seeing if it drops. If it doesn't, I'd be looking at the router.
And out of curiosity, what if it does end up correcting itself? Would there be ome way to take care of the issue?
