Fishtechy's avatar
Fishtechy
CM500V default settings
Hello, just got a CM500V for xFinity but I don't have an Ethernet port on my laptop nor do I have a pigtail handy. Does anyone know the default psk for the default SSID?
  • plemans's avatar
    Jul 03, 2020
    The CM500v is a modem only. there's isn't a "default ssid". Theres no integrated router function.
    You'd either need a device with an ethernet port or a router to connect to it.
