Fishtechy
Jul 03, 2020Aspirant
CM500V default settings
Hello, just got a CM500V for xFinity but I don't have an Ethernet port on my laptop nor do I have a pigtail handy. Does anyone know the default psk for the default SSID?
- Jul 03, 2020
The CM500v is a modem only. there's isn't a "default ssid". Theres no integrated router function.
You'd either need a device with an ethernet port or a router to connect to it.
Jul 03, 2020Guru - Experienced User
Fishtechy
My bad, apparently I cannot read.
Never mind. Thank you
