BobModem
Dec 23, 2019Initiate
CM500V Voice doesn't work with Xfinity
Hi, I changed to Xfinity a month ago. It came with the Xfinity modem which worked fine. I purchased the CM500V, switched from the Xfinity modem, called Xfinity and had them change everything over....
- Jan 02, 2020
OP here...I called Xfinity and they hadn't activated voice. They did and it works now. I guess I should have just called them first, but I dread calling cable companies. To their defense, calling them wasn't that bad. Good expereince and I'm all set now.
lwccoffice
Dec 24, 2019Tutor
BobModem, I am having the same problem. Purchased same type of device recently as you--returb from Amazon. Have been a subscriber for years with a working setup but wanted to quit leasing Comcast equipment. I can't even get the Comcast techs to activate the device for voice. (They did so for Internet.)
lwccoffice
Dec 24, 2019Tutor
More info: Another tech I just talked to said that there is a difference between Comcast residential (aka Xfinity) and Business. I have Business service. With Business, bring-your-own voice modems are not allowed.
