sferrell615
Nov 01, 2020Aspirant
CM500V with Comcast - other Comcast landline callers cannot hear me when calling landline phone
I am one of a large number of people having a Comcast phone issue (caller cannot hear me) and the issue appears to be Netgear modem related so I would imagine that Netgear would help to resolve this ...
- Mar 10, 2021
The steps below resolved the problem for me.
The problem has been resolved for several months and has not returned.
- browse to https://connect.xfinity.com/voice/settings/callforwarding
- login (if needed; perhaps re-browse to the address above thereafter)
- remove all numbers except 'home phone'
- disable 'home phone'
- enable 'home phone'
- perhaps remove 'selective call forwarding' numbers (?)
I did not test right-after doing this... I tested 1-2 weeks later (at which point it worked as expected). Therefore I am not certain that this is the fix but I have had a ticket open with Netgear for several months (nothing has been done) and no one has offered other solutions.
sferrell615
Dec 31, 2020Aspirant
netgear customer support at it's finest...
NETGEAR Support
2020-12-29 0:40:58
Dear Scott, Good day! We are still looking into this issue. We hope to fix this issue in our next update. We really appreciate your patience and co-operation. Thank you again for your letting us know about this issue, as this will help us improve our products. Have a great day! Regards, Praveen Netgear
then 1-2 days later...
This case has already been closed, please log a new support request if you require further help.
in total, i provided 8 responses to the netgear customer support rep over 1.5 months and out of nowhere the ticket was closed.
now, the problem has been resolved for 2 weeks; however, since it appears that netgear has done nothing to resolve the problem and i did perform a change on comcast's end (the ISP) i wanted netgear to continue to investigate for others that have this problem (again, according to the comcast forum [mentioned in a previous post above]).
the change that i made on comcast's end was to log into my comcast account and remove all numbers being forwarded to including disabling the home number, saving, re-enabling the home number, saving. i did not test to see if this issue was resolved right after i made this change, so when i realized that this problem was resolved i didn't know if it was resolved because of a netgear change or the comcast change.
one person on the comcast forum said that this comcast change resolved the problem for a local comcast number but not a long-distance comcast number.
i don't plan to re-open a ticket with netgear... unless people think that i should. let me know.
Dec 31, 2020Guru - Experienced User
it would be wise to keep in contact with NG support. Theres nothing we can do to help you out here in the forums.
Good Luck.
