crazyoldhermit's avatar
Jan 03, 2022
CM600 - Cannot open 192.168.100.1
Today my modem stopped working, and my router freaked out too. (I thought the router was the issue, restored it to an older working configuration, and solved that part of the problem. LAN is restored....
  • crazyoldhermit's avatar
    crazyoldhermit
    Jan 04, 2022
    So, I was unable to get a different result following that procedure. I ended up purchasing a new modem to solve the problem immediately, as we didn't have time for extended downtime.
    The modem was entirely unresponsive to any attempt at accessing the administration console. That is the only obviously "broken" part of the device. Now that it is doing nothing, I will futz around with it, but I am not sure how much I will be able to do without an external USB. Of course, I may rip it apart and then I can USB into the mainboard (I am guessing) but not sure if I care that much.
    Anyways, I wanted to share the results. If there is a method to tinkering with the device in an "offline" mode, point me in the right direction please :)
