crazyoldhermit
Jan 03, 2022Star
CM600 - Cannot open 192.168.100.1
Today my modem stopped working, and my router freaked out too. (I thought the router was the issue, restored it to an older working configuration, and solved that part of the problem. LAN is restored....
- Jan 04, 2022
So, I was unable to get a different result following that procedure. I ended up purchasing a new modem to solve the problem immediately, as we didn't have time for extended downtime.
The modem was entirely unresponsive to any attempt at accessing the administration console. That is the only obviously "broken" part of the device. Now that it is doing nothing, I will futz around with it, but I am not sure how much I will be able to do without an external USB. Of course, I may rip it apart and then I can USB into the mainboard (I am guessing) but not sure if I care that much.
Anyways, I wanted to share the results. If there is a method to tinkering with the device in an "offline" mode, point me in the right direction please :)
Jan 03, 2022Guru - Experienced User
The isp issues a public ip address to 1 device. And sometimes it can take a bit for that IP address to be released to be reassigned.
Try this.
Factory reset the modem with it disconnected from the laptop/router. Disconnect it from the laptop/router.
Push and hold reset for 7-15 seconds while powered on. Let it reboot.
Then power off the modem and again make sure its disconnected from everything. Even the coax. Power off your laptop.
Give it a couple minutes a minimum.
Connect the coax back to the modem.
Power it on. Wait at least 2 minutes for it to fully boot.
Connect the lan cable to your laptop.
Power your laptop on. Let it fully boot.
Once its fully booted, then attempt to use internet/access the modems setup page.
If that works, the modem should be fine and it might have just been the ISP not releasing the address.
crazyoldhermit
Jan 03, 2022Star
Thanks for your procedure, I will work on it now. I have the ISP tech coming to check the lines between next 20min>100min, so I ought to have time for this process. I have done parts of it, including a full disconnect including coax, but I have not done all of it in the order specified.
- crazyoldhermitJan 04, 2022Star
- plemansJan 04, 2022Guru - Experienced User
You can try tinkering with it offline but you won't get very far. They do a pretty good job of locking down the modems as if people could tinker with them, they could set their own speed tiers.
Is it still within warranty? You could always check your warranty status.
Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process and check your warranty.- crazyoldhermitJan 04, 2022StarIt is well beyond the warranty period, which was only a year long anyway. New modem has a two year, and hopefully it lasts much longer :)
The homelab is back up. Hooray.
MB8611>SG-2100>Pi-Hole>Nighthawk MR/MS in AP mode
(getting the MR60 to broadcast internet can be a bit of a PITA at first, but it always works eventually. Oddly the satellite always works fine)
