Mongo-xbl
Aug 06, 2016Aspirant
Cm600 - firmware update
How do I update the firmware when an update is available? Talking to Comcast they are saying an upgrade to docsis 3.1 is coming at the end of the month.
- Dec 14, 2016
Artemas: Firmware updates for cable modems are pushed out by the ISPs. Your modem will update the firmware when it is released by Comcast/TimeWarnerCable/Spectrum etc., who will get it from Netgear and release it throught their network to the compatible cable modems.
There is no firmware download for the consumer to update the CM600 themselves. Best advice is to contact your ISP and ask them to contact Netgear regarding the firmware update.
Artemas
Dec 14, 2016Aspirant
OMG! you make this so difficult!
HOW DO I UPDATE MY CM600 FIRMWARE. Its just that easy of a question.
You had a previous post on this and then closed it with no link to the firmware!
Please explain (in 5th grade language) how to get the firmware update 1.3.0.12 and how to update it to the CM600
Thanks!
Artemas
I already checked the product drilldown and downloads area of support. It says no firmware info available. So where is the firmware downlaod at for the specified firmware above?
- Sparky78Dec 14, 2016Guide
- pete_aDec 22, 2016Initiate
I've called TW/Spectrum and they say they do not upgrade firmware of user owned equipment. They told me you get what's out of the box, that's it. They are aware that there is no way for the user to upgrade as well. Solution rent a modem from them.
Also good luck getting provisined for more than 4 upstream channels.
