jcafaro10
May 19, 2020Aspirant
CM600 - slow speeds, is it the modem or Comcast?
Hello all, Just got a CM600 to go with my 200mbps Comcast plan but I'm only seeing speeds around 20mbps. I've tried contacting them and they've had me power cycle it, replace coax cables, etc bu...
jcafaro10
Thanks for the response. I only have one cable line that enters the house and it's not split. The coax cable connected to it is fairly short and looks fine.
Ive had them reprovision the modem and reset it and that hasn't seemed to work. I guess I can try exchanging the modem and see if that helps. The modems run overnight and I see a lot more correctable and uncorrectabkes in these channels, and channel 16 still isn't locked.
| 14 | Locked | QAM256 | 37 | 609000000 Hz | 6.7 dBmV | 40.1 dB | 4 | 0 |
| 15 | Locked | QAM256 | 38 | 615000000 Hz | 6.7 dBmV | 37.7 dB | 361412 | 85 |
| 16 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 17 | Locked | QAM256 | 40 | 627000000 Hz | 6.7 dBmV | 29.2 dB | 63118 | 163135 |
| 18 | Locked | QAM256 | 41 | 633000000 Hz | 6.8 dBmV | 40.3 dB | 3140 | 1147 |
jcafaro10
May 20, 2020Aspirant
Hello again,
I went to target and picked up an SB6190 which seemed to completely resolve the problems after activating. Speeds were up to 200mbps as expected. After several hours speeds seemed to come back to around 20-50. I took a look at the status page and noticed something interesting. While the channels don't entirely line up (and I seem to have some more of them on this modem) it looks like the frequency ranges (615-633mhz) match up between both modems where there's an issue! I'm guessing that means the issues I'm having are not modem related. Thoughts?
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Corrected | Uncorrectables |
| 1 | Locked | 256QAM | 16 | 471.00 MHz | 6.00 dBmV | 38.98 dB | 0 | 0 |
| 2 | Locked | 256QAM | 17 | 477.00 MHz | 5.90 dBmV | 40.37 dB | 0 | 0 |
| 3 | Locked | 256QAM | 18 | 483.00 MHz | 6.20 dBmV | 38.98 dB | 0 | 0 |
| 4 | Locked | 256QAM | 19 | 489.00 MHz | 6.10 dBmV | 38.98 dB | 4 | 0 |
| 5 | Locked | 256QAM | 20 | 495.00 MHz | 6.10 dBmV | 38.98 dB | 9 | 0 |
| 6 | Locked | 256QAM | 21 | 507.00 MHz | 6.00 dBmV | 38.61 dB | 0 | 0 |
| 7 | Locked | 256QAM | 22 | 513.00 MHz | 6.00 dBmV | 38.98 dB | 0 | 0 |
| 8 | Locked | 256QAM | 23 | 519.00 MHz | 5.90 dBmV | 38.98 dB | 0 | 0 |
| 9 | Locked | 256QAM | 24 | 525.00 MHz | 5.90 dBmV | 38.61 dB | 15 | 0 |
| 10 | Locked | 256QAM | 25 | 531.00 MHz | 5.90 dBmV | 38.98 dB | 8 | 0 |
| 11 | Locked | 256QAM | 26 | 543.00 MHz | 5.90 dBmV | 40.37 dB | 0 | 0 |
| 12 | Locked | 256QAM | 27 | 549.00 MHz | 5.90 dBmV | 38.98 dB | 0 | 0 |
| 13 | Locked | 256QAM | 28 | 555.00 MHz | 6.20 dBmV | 38.98 dB | 1 | 0 |
| 14 | Locked | 256QAM | 29 | 561.00 MHz | 6.20 dBmV | 38.98 dB | 2 | 0 |
| 15 | Locked | 256QAM | 30 | 567.00 MHz | 6.20 dBmV | 40.37 dB | 0 | 0 |
| 16 | Locked | 256QAM | 31 | 573.00 MHz | 6.10 dBmV | 38.98 dB | 0 | 0 |
| 17 | Locked | 256QAM | 32 | 579.00 MHz | 6.30 dBmV | 38.98 dB | 0 | 0 |
| 18 | Locked | 256QAM | 33 | 585.00 MHz | 6.50 dBmV | 38.98 dB | 0 | 0 |
| 19 | Locked | 256QAM | 34 | 591.00 MHz | 6.40 dBmV | 38.98 dB | 1 | 0 |
| 20 | Locked | 256QAM | 35 | 597.00 MHz | 6.60 dBmV | 40.37 dB | 0 | 0 |
| 21 | Locked | 256QAM | 36 | 603.00 MHz | 6.60 dBmV | 38.61 dB | 0 | 0 |
| 22 | Locked | 256QAM | 37 | 609.00 MHz | 6.80 dBmV | 38.98 dB | 2 | 0 |
| 23 | Locked | 256QAM | 38 | 615.00 MHz | 6.60 dBmV | 38.61 dB | 301 | 24 |
| 24 | Not Locked | ---- | 39 | 621.00 MHz | ---- | ---- | ---- | ---- |
| 25 | Not Locked | ---- | 40 | 627.00 MHz | ---- | ---- | ---- | ---- |
| 26 | Locked | 256QAM | 41 | 633.00 MHz | 6.90 dBmV | 37.30 dB | 65505 | 57591 |
| 27 | Locked | 256QAM | 42 | 639.00 MHz | 6.70 dBmV | 38.90 dB | 0 | 0 |
| 28 | Locked | 256QAM | 43 | 645.00 MHz | 6.70 dBmV | 39.50 dB | 1 | 0 |
| 29 | Locked | 256QAM | 44 | 651.00 MHz | 6.40 dBmV | 39.20 dB | 2 | 0 |
| 30 | Locked | 256QAM | 45 | 657.00 MHz | 6.40 dBmV | 39.20 dB | 0 | 0 |
| 31 | Locked | 256QAM | 46 | 663.00 MHz | 6.40 dBmV | 39.50 dB | 2 | 0 |
| 32 | Locked | 256QAM | 47 | 669.00 MHz | 6.40 dBmV | 39.50 dB | 2 | 0 |
- plemansMay 20, 2020Guru - Experienced Userthoughts are you're probably correct, I'd have the isp check the line since its happening with 2 different brand of modems.
