wzee
Oct 21, 2019Aspirant
CM600 and RCN stopped working
CM600 cable modem suddenly stopped working with RCN. downlink light - solid yellow uplink light - blinking yellow I looked up the modem logs and says "no ranging response received - T3..." ...
- Oct 21, 2019
I'd say something is wonky. its a technical term. :)
Reason I say that is that the cm600 is a 24x8 channel modem. You've only got one channel showing but even the one channel's power is way out of spec. You're power is way to low, your snr is low, and its not locking in with your provider. You said your isp is going to come check your line? That's what I'd highly recommend with your connections page.
wzee
I said yellow so yeah it could be amber but definitely not red or green.
Also was able to get these snippets...
Oct 21, 2019Guru - Experienced User
- wzeeOct 21, 2019AspirantThanks for your insight.
Yeah, tech is coming out tomorrow. Will let you know how it turns out.
Also I was able to pickup an ISP modem to test if issue was with my CM600 and their modem did not work so my CM600 s/b fine.- wzeeOct 22, 2019Aspirant
Long story short, issue was a failed connector in the building's communication closet.
Uncertain if connector deteriorated and/or another ISP technician distrupted my connection in the closet.
RCN technician replace the connector and all is good.
Thanks for you input.
