elewis566
May 18, 2021Aspirant
CM600 and Suddenlink tap issues?
Here is a screen shot of the latest Cable Connection info. This was an hour after it rebooted. I have had 2 techs come out and re-terminate all the lines. One actually went to the Tap and checked th...
May 19, 2021Guru - Experienced User
So you've got errors in your line. The techs have said theirs errors in your line. The neighbors are all having issues.
this really seems to be an ISP issue and not a modem issue.
elewis566
May 19, 2021Aspirant
I agree. They keep telling everyone that it is our equipment. I have another tech coming tomorrow.
Just had another outage. Here are the logs during that outage.
2021-05-19, 10:24:37 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:bf:a2:a8;CMTS-MAC=00:01:5c:b4:c8:4b;CM-QOS=1.1;CM-VER=3.0; |
2021-05-19, 10:24:36 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:bf:a2:a8;CMTS-MAC=00:01:5c:b4:c8:4b;CM-QOS=1.1;CM-VER=3.0; |
2021-05-19, 10:24:36 | Error (4) | Primary address failed, secondary active;CM-MAC=08:36:c9:bf:a2:a8;CMTS-MAC=00:01:5c:b4:c8:4b;CM-QOS=1.1;CM-VER=3.0; |
2021-05-19, 10:24:31 | Critical (3) | DHCP failed - RS sent, no RA received;CM-MAC=08:36:c9:bf:a2:a8;CMTS-MAC=00:01:5c:b4:c8:4b;CM-QOS=1.0;CM-VER=3.0; |
2021-05-19, 10:24:14 | Notice (6) | Honoring MDD; IP provisioning mode = APM |
2021-05-19, 10:24:02 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:bf:a2:a8;CMTS-MAC=00:01:5c:b4:c8:4b;CM-QOS=1.1;CM-VER=3.0; |
2021-05-19, 10:19:48 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:bf:a2:a8;CMTS-MAC=00:01:5c:b4:c8:4b;CM-QOS=1.1;CM-VER=3.0; |
