marshallll's avatar
marshallll
CM600 and Suddenlink
I recently upgraded from an Arris SB6190 afte learning about the puma 6 issues while dealing with some inconsistent connectivity with my cable internet. Those connectivity issues resolved themselves ...
  • marshallll's avatar
    marshallll
    Feb 07, 2020
    turns out the initial Suddenlink rep did not properly provision the CM600 with the 400mbps speed under my plan.
    I am getting 400mbps now. Thanks for your help guys! I've learned a lot
