marshallll
Feb 06, 2020Aspirant
CM600 and Suddenlink
I recently upgraded from an Arris SB6190 afte learning about the puma 6 issues while dealing with some inconsistent connectivity with my cable internet. Those connectivity issues resolved themselves ...
- Feb 07, 2020
turns out the initial Suddenlink rep did not properly provision the CM600 with the 400mbps speed under my plan.
I am getting 400mbps now. Thanks for your help guys! I've learned a lot
marshallll
Feb 07, 2020Aspirant
Feb 07, 2020Guru - Experienced User
Glad to hear you got it working properly! Let us know if you have further issues.
If you mark it as solved, it'll help the next person with this issue.
