pshirt
Feb 05, 2016Aspirant
CM600 cable modem failing after large downloads
Hi- I'm using a CM600 modem with a WNDR-3700v4 router. Recently, the cable modem has started behaving very oddly after downloading large files (1GB or so seems to be the trigger point). Afte...
- Feb 15, 2016
The modem has been replaced and the issue has disappeared. Yay warranty.
DarrenM
Feb 10, 2016Sr. NETGEAR Moderator
Pshirt
It is in the same location you just need to select the Cable Connection button and if you could screen shot that page we can investigate the issue.
DarrenM
pshirt
Feb 15, 2016Aspirant
